1 - 6 of 6 Posts
I just bought a K24a2 from a tsx and a 06-11 civic si lsd transmission, I have been trying to find what exact ecu is the best to use for the k swapped eg. I was planning on using the K Tuned K series conversion harness.
Yes 02-04 kpro, 02-04 engine harness with charge harness and conversion harness. For a k24 you may need to re arrange the pins on the crank sensor as well as your vss sinse you have the countershaft speed sensor
Basically you're going to set the car up like an RSX-S, btw k24 block is a bit taller than the k20.
1 - 6 of 6 Posts
