21 - 31 of 31 Posts
ProspeedCTR said:
Won't this throw the balance of the crank off?
How will this throw off the balance of the crank? I thought it just lets you rev a little faster...:up:
The size difference in the OEM crank pulleys will either under drive or over drive the accessories attached to it, both are internally dampened so it shouldn't affect the crank.
Scared the shit out of me damn. :p
I couldnt find anything close using the K24 pulley, that belt doesnt exsist. If you swap on a K20 crank pulley you can use a Fan belt from a 92 Infinity Q45.
yea but i dont want to underdrive the alternator or the water pump, their is a reason y honda made it bigger, if it didnt matter they would of put the k20, i think am just going to get the ep3 pulley setup and call it a day, just to be safe
back from the dead :rolleyes:
looking for proper length for K24 with A/C & ep3 idler pulley (no power steering) & K24 crank pulley :facepalm:
edit:
65.8" belt (66.5" OD) part # 658K6 or 4060658. the next closest would be 66" (66.75" OD) 4060660.
I had 4060663 which worked for several months but recently started slipping BAD because the belt is a little too big. I have standard ep3 now 4060653 (65.3") & its too short & too tight on the tensioner & pulley
Bumping a great thread. I have a jdm k24A, swapped the water passage, new alternator, new tensioner, k-tuned idler pulley...I lost the k-tuned belt. Got the K070500 that the MR2 guys use but I guess I need the k20 crank pulley or a 52" as it's too short.
Edit- Looks like a 7PK1325 will work for me. K-tuned lists a 7PK1320 replacement.
Dayco 5060520, or 520K6 from Autozone (6 rib).
21 - 31 of 31 Posts
