Do you know what is needed to be modified to be able to use the other blocks with rsx parts and internals?nikos said:From what I understand, the CRV is the only one that will accept a k20a2 oil pump without any modifcation. The accord, element and TSX blocks have a oil girdle that has a raised ridge or hump right down the middle. Other than that, they appear to be the same. Of course they each have different internals.
So none of the blocks have the squirters? The TSX is drilled for them but doesn't have them?HONDA GHANDI said:Do none of them have oil squirters? I noticed they have (tsx K24) the bosses for them. I was going to try and drill the block for squirters on my setup.
