K-Series Compression Calculator
K-Series Compression Calculator by Zealautowerks.
www.zealautowerks.com
works well. Found the dome volume of the pistons offered or from the CR stated for the K20 to determine the dome volume.
Then switch over to k24 and enter that dome volume to calculate the CR. It is going to be higher than the corresponding K20 Cr with the same piston dome volume.
