121 - 138 of 138 Posts
I FINALLY FOUND OUT A WAY TO CLEAR MY SWAY BAR FOR KRRH/Crsxrh WITH K24 SWAP!!!!!! i am currently running a stock ep3 front sway bar with 2003 civic DX rear Endlinks in the front and it actually make the sway bar moved back instead of forward where its hitting the headers. I tired with em2 25mm sway and it didn't really give a good amount of clearance as the stock Ep3/RSX sway bar.
2003 civic ex rear endlinks used for the front ep3 sway bar
PS. this with work with ep3/rsx, em2 24mm front sway bar. it might work with other sway bars but i haven't tested it out.
UPDATE:
K24a2 RSX
Skunk 2 Raceheader/HKS Exhaust
EM2 15mm Swaybar/EM2 swaybar bushing cause RSX are too large.
Installed EM2 sway finally with stock RSX endlinks. Had to buy EM2 sway bushing because RSX 25mm are too large. If you already have 15mm somewhere then you can use those. Clearance is minimal at best, but rarely ever contacts. When it does it's a faint clink.Usually when it's cold and at start you first drive over a speed bump.
no front sway to 15mm EM2 sway w/27mm Rear Progress Adjustable Sway impressions. The steering feels tighter and does what it was designed to do. Reduces sway, so it hugs turns better and doesn't roll as much.
I spun out in the rain and it did a doughnut. Without the sway I probably would have curbed instead of kept spinning into a doughnut? IDK? Driver mod? lol
I have both H&R front and rear anti-roll bars. Rear has 20mm and front 28 mm , both are adjustable (hard and soft) - I have them set both on soft.
By the way the German TUV for this kit, covers only the use of both sway bars at the same time (or only the front one :) ).
Bellow is a message from their technical department H&R Germany:
It is absolutely not ok to use the rear bar alone for road use. To be clear: It is forbidden!!!
Excessive oversteer may occur and you dribeve without TUV approval..
Once you have both anti-roll bars from H&R fitted you can do fine tuning to reduce understeer. (Use the outer bores front and the inner bores rear.)
Sent from my mobile phone
Update. After the first week or so, no occasional clinks at all now. It's perfect. No sounds, clinks or anything at start up, warm up, or even under hard acceleration. The bushing must have flexed enough to grant that extra little clearance
EM2 15mm sway
Skunk2 Megapower RH-HKS 65mm Exhaust
Progress adjustable 27mm rear sway
02 dc5 type s k20a2/k24a2 set up soon , want to run dc5 type r exhaust manifold and cat. with 05-06 type s oem catback set up. i placed order for the em2 25mm front sway, woud this clear the type r exhaust manifold ,cat???
CHASSIS: DC5 (06 RSX-S)
HEADER: JDM DC5-R
SWAY: FRONT-STOCK
REAR-DC5-R
NOTES: Feels aggressive on tight corners, DC5-R Suspension, no rubbing issues.. next mod Mugen Rear Sway-bar and DC5-R Front Sway-bar plus Spoon 4-2-1 Headers
My asp header comes in Monday and I'm going to try to clear my itr front sway. :raisins:
This is on a k24 ep3. Told Stefan I'm using the itr front sway too so we'll see how it is.
From my personal experience the following fit for me:
My car: 2005 RSX-S
Header: JDM DC5-R 4-2 & 2-1 Header
Additional Header: JDM DC5-R 4-2 & Spoon 2-1 Header clears as well
Sway Bar: 25mm EM2 Front Sway bar (OEM Type-S bar doesn't clear of course)
Mounts: Energy Suspension Inserts
Engine: K24a2
Exhaust: Full Type-R catback
Note: The passenger side pipe of the lower 2 pipe section of the header touches the header when the car is jacked in the air but clears just fine after the car is lowered to the ground as the middle section lifts up. No rattling or header noise ever with this setup.
PLM Race Header information (switched to this):
PLM (Club RSX) Header does NOT clear the front sway bar for me. EM2 (25mm) sway bar is horrible clearance with the PLM. OEM Type-S (05) sway bar actually clears a big better but still touches it pretty hard both in the air and on the ground. The smaller EM2 (15mm) I think clears better but I don't want to go with a 15mm front sway bar (auto-x reasons). I am deciding between searching for a better clearing sway bar (Toda perhaps) or getting the header modified to be extended since I want to do a high flow cat on it anyway as well. Modifying the header is winning at the moment.
I should also add that my PLM header is welded in all the joints so it's fully put together. I know some have said you can sorta half insert the connections together to extend it that way. I didn't want leaks so I didn't do that so mine is fully assembled tight.
Chassis: usdm ep3 w/k24a2
Header: invidia race header for euro ep3 (type r?) 4-2-1 with 2.5 outlet
Swaybar: stock
Notes: remove sway then install header, install sway by sliding over the header from the rear and twisting to make fit. the fit is very tight and if sway is not centered it hits. catback had to be cut in a couple places and re-welded to fit properly but nothing 75 bucks and half a hr did not take care of at a local shop.
must use 75a or harder motor mounts plus check heat shields for clearence and bend as needed.
kit does not come with head to manifold gasket, inside of header was very dirty with metal shavings and abrasive dust, also there was a defouler welded inside for the secondary 02. cost was under 600 delivered. no flex pipe on this one:new_slayer:
All that headache to make a k20 header fit a k24. It's amazing how easy things are when the right parts are used. No rigging shit, no hoping shit fits. It just works.
well i wanted a fully welded race header that was 4-2-1 with 2.5' outlet made of stainless in non sequential pairings made to fit my specific chassis. and all of this for the least possable price that had great reviews . sure i could have spent 1400-1700 on a custom made header or huge name brand. what would you have used instead that would run less than 600 bucks in stainless,fully welded without slip joints requiring springs or bolts or a flex pipe that always breaks. plus is able to fit the constrictive chassie/sway bar. :confused:
Chassis: 2002 civic dx
Engine: k24/k20 frank
Drivetrain: k20z1/3 case, ep3 1st, 2nd, rsx-s 3,4,5,6, z3 lsd
Header: PLM race header 4-2-1, just like k tuned header. Fits fine with very small clearance of the sway while frame is still not bolted up to car. Will post pics once it's bolted up to the car frame.
Chassis: 2003 ep3
Engine: k24a2
Header: OBX V2(Comptech rep)
Front Sway: None
Notes:
I would like to know if anyone has cleared any front sway with the OBX V2(Comptech rep) RH. After researching I haven't found anyone fitting anything, a few guys say even the 16mm em2 front sway won't clear. Any help would be appreciated, thanks.
Chassis: 03 rsx type s Dc5
Engine: k24a2
Header: stock k20 header
Swaybar: stock
Mounts: innovative
No clearance issues at all.
I know this is a bit old but I thought I'd add mine :)
Chassis: 02 Rsx
Header: oem + cat (type s)
Swaybar: 02 Type S (OEM)
Notes: Everything fits nice, however, as I shift, there is a slight knock. I have yet to check where it's coming from. I'm sure it's the cat hitting the sway bar.
