1 - 20 of 122 Posts
Tuned an EG civic with a stock K24 Accord bottom end with a K20A2 head..
One-Fab top mount manifold
GT35R T4 .68A/R
One-Fab 26" x 12" x 4" Monster Intercooler Core
Tial 44mm WG
Tial BOV
750cc injectors
Walbro 255
Aeromotive regulator
GM 3 bar MAP sensor
@ 12.8psi the car made 467whp
Soon after the car went to the track and spun the tires in 1st and second and the the clutch slipped in 4th 5th and 6th.. and ran 11.3 @ 127. The car should be getting a clutch soon and should be hitting 10s then its time for a built motor and more boost.:)
No More Honda, Its EVO 8
Motor is completely stock, its a k24a1 from crv, k20a2 complete head with type s cams. Type s transmission w/welded diff
Pipes are 2 1/2" from turbo to fmic, and 3" from fmic to throttle body which has a wiggins clamp attached to it
Btw, its a stock clutch and flywheel which is slipin already
Will post up a video later on today
must see video...
EMS or K-pro?
Discussion Starter #13
The torque was around 330 if I remember correctly, The problem is that the clutch started slipping on the dyno. So the torque actually read low. Once he gets a clutch in there we can retune. If I can remember correctly the package is around 4800, however the price of the Garret stuff keeps going up, so that number may change.
how long did it actually take for you to recieve ur one-fab manifold
yah the car looks fast as shit... You can hear the clutch slipping though...
what kind of tires were you guys using at the track? and whats up with the missing hood?
damn that hatchback is sick. really fast and u need get the block built fast tooo.
im gonna have the same set-up but built block..all i need to do is get intercooler piping...good numbers what rpm are you taking it too?
1 - 20 of 122 Posts
