no you cannot, not sure on what the correct way to do it tho to make it work. I qoute nikos, "If you get one (tsx motor), you have to replace the throttle by wire with a normal TB assemply.. Also the tsx intake cannot be replace with a type r intake or the type s intake. The RBC would fit I guess.. "excelcivicsi said:could you just use a rsx TB and still use the tsx manifold?
i have not done too much research on the tsx motor. the dyno numbers look very promising :dance:
it should. I would think it would fit nicer as well since it wouldn't hang as low.Does anybody know if the OEM TSX header will work with a TSX motor in an EK?
