I have been registered for a week and am looking about doing a K24 swap into the CRX, i want to do a K20a2 into it, but i was wondering if want to put a k24 into a crx i wanted to know that with the hasport kit you have to buy an extra bracket from honda for the mounts to work properly. but i also was wondering about if you change the intake manifolds and put a k20 manifold with its throttle body on a k24 will it work and can you use a stock RSX harness for the swap or do you just send some place like hybrid or hasport a TSX harness and your old harness, does anyone know how different the tsx and rsx harness are different, also are the blocks the same height or are there more lower clearance issues with the k24s. Thanks if anyone knows this info.
