1 - 1 of 1 Posts
1993 EG Hatch
Why are you stuck with a K24a1?
A K24 at 8k rpm's is not going to live very long in endurance racing. I would recommend not exceeding the OEM rev limit (7,200?) and might even try to limit it a little less, depending on how long you want your engine to survive.
I hear good things about the Drag Cartel Endurance 2.2 cams. You will also want the 50 degree cam gear to help bump the mid range torque. You will need to clay the valves to find your maximum cam gear advance with the cams you chose.
I think you are going to have a hard time getting 200hp over a 2,000 rpm window for an endurance engine on pump gas.
1 - 1 of 1 Posts
