1 - 7 of 7 Posts
k24a2 and k20a2 aftermarket header arnt the same right? and does anyone knoe what company makes a header without the two longer pipes like rcrews. my four door has abs and i believe its in the way. :down:.. but im not lookin for dc header something better lol
what two pipes are you talking about?
The ASP header should fit the 4dr with out problems.
i think what he is refering to is the secondaries.. meaning a 4-1 ... yes there's people that make the header ASP above and myself.. Yes there is slight difference in deck height of the motor so if you guy for one or the other and try to use it.. either one is going to sit to low or two high...happy shoping
Discussion Starter #4
what is it... cylinder 3 and 4 sticks out more?
check it out
doesnt stick out as much
i have abs on my four door and i believe their a clearance issue
the retraded crew header piping does come out a bit. mine is similar..
Discussion Starter #6
ya i need to look for a decent one that doesnt stick out as much. and the k20 and k24 header are different correct?
Yes they are different. The k24 has a taller deck hight by allmost 3/4" than the k20.
We have a k24 header that will work for what you need.
We build all our headers custom to work for you set up. Shoot me a pm is you are interested.
Stefan
1 - 7 of 7 Posts
