tyflip2 said:
would shot peening the rods be an option? how much does that generally cost. i also want to throw another option out... would i be able to run a moderate amount of n2o with an 11:1 compression ratio with stock rods and aftermarket pistons. just trying to figure out what i want to do by looking at it from every angle
there's no real way to answer the question "would I be able to". It's too dependent on too many different factors. My personal opinion, though? I think it would be extremely foolish not to go to aftermarket rods if you already have the motor apart. If I am going to push a motor to it's limits I want to be confident that everything is built to be strong as fuck because I like to beat the fuck out of it. If you are not confident in your motor when you are driving you won't drive as hard which translates to more hesitation and slower times.
Also how would you feel if you saved the money on rods only to junk your $7000 motor by blowing a rod through the block? I have
personally seen
four k motors with holes in the block from broken rods. Push these motors hard enough and the rods will break. On the other hand unless you do something very wrong you will not break a Crower, Eagle, etc.
Read that HyTech article in the other post. John from HyTech says that the only weak link in the K series is the rods. Jeff Owen of Special Projects Racing, who is at the forefront of K series developement for road-racing applications, told me exactly the same thing. Why skimp out now and regret it later? Better safe than sorry.
oh and I apologize if that was a rant...
