21 - 33 of 33 Posts
which engine harness did you use? FN2 or FD1?
I'm guessing you are using the FN2 ECU? does it have any problems talking with the rest of the electrical system?
freagin NICE!!! Damn and you work fast as hell or what?
Discussion Starter #24
FN2 engine harness, the ecu plugs all line up and plug in... there are some minor differences with the charging system so you need to change some wires around, otherwise you be blowing up fuses when you turn the key to start the car. Car will start but charging indicator light will show.
As for the rest of the system as stated before VSA and EPS will need to be disabled in the Flashpro. The Honda HDS will be needed to reprogram the immobilizer and match up the keys
You will need to Run the 4 wires on the Primary and Secondary Oxygen Sensors back to the main engine loom that runs back to ECU plugs.
I'll be switching over to Innovative 60A 8th Gen Civic street mounts, the FD2 upper torque/dog bone mount is a few inches short and cant be used. Appears the FD1 chassis mounting bracket has a different mounting position.
FD1 (R18) drive shafts will work with any K20a intermediate shaft
FN2 header is not going to fit so an aftermarket header or a factory FD2 header is ideal.
DC5 Power Steering Pump and DC5 accessories belt is needed. The R18 high pressure power steering line will need to be modified with a DC5 pump line fitting.
Power Steering return line needs to be extended and re-routed back to the overflow bottle
A/C Lines use a FD2 line for the core to pump (short line). From the firewall to the pump, the FD1 (R18) hose will need to be modified and extended with the K20Z fitting at the end to fit the pump.
If the chassis brackets don't match up for the top mount, how are you driving your car around now? I have a similar project planned for my FD1 in India. Your thread is my bible. :D
Of course, I have to deal with an A/T car too. Any idea how hard that'll make the job?
Discussion Starter #27
Get yourself the Innovative 60A mounts :up: you wont need the upper dog bone mount!
As for the AT, the electrics will be a challenge, if you get the helms manual it should provide you all the answers good luck!
is there a web site where I can find oem honda parts for the European market, I would appreciate your help. I want to get started on my swap soon
Discussion Starter #30
Your car would be left hand drive, we can refer you to dealers from the US as they are Left Hand Drive.
Your Local Honda dealer may not have a listing for some of the parts
can you post pics of your engine bay having those mounts?
or anybody here tried installing those mounts I would like to see it installed. thanks
hi
Do you need to change the cross member complete unit.
We dont get fd2 or SI here, we only have fn2 and cl9 K24 accord.
Can i do a swop and keep r18a1 cross member and all?
21 - 33 of 33 Posts
