1 - 1 of 1 Posts
Hello there guys and girls,
This is my first post here on K20a, and hoping some of you knowledgeable lot can help me out with my predicament.
Last week I took my fn2 Type R for a trackday at Silverstone - unfortunately this was cut short after an hours running due to cylinder 1 rod bearing deciding it was no longer good for this world. I am led to beleive this is due to the lack of a baffled sump & balance shaft pump fitted as standard. (pics of the damage below)
In order to prevent this happening again - the first plan is to fit a baffle and balance delete.
I have sourced a new engine - in a complete car, that has got no third gear and plan to remove the engine for this to directly transplant into my original car.
I then plan to use my old head to do a k24 frankenstein and aim for 300bhp NA.
I plan to do the engine swap this weekend as i need to get myself back on the road ASAP, however this will all be done on my driveway infront of my garage.
Does anyone have any tips for removing/fitting a K20Z4 engine in an FN2 ? Is it best to remove from above or below ? the same question for re-fitting ?
Thanks in Advance
Andy C
101437
101438
101439
1 - 1 of 1 Posts
