K20 z3 part out has a spun rod bearing that is Still fixable with an over sized bearing.
Tbo · Registered Joined 12 mo ago · 4 Posts Discussion Starter • #1 • 12 mo ago K20 z3 part out has a spun rod bearing that is Still fixable with an over sized bearing.
B Brotatochip · Registered Joined May 15, 2019 · 385 Posts #2 • 12 mo ago Depends. You will need to take the crank/rod to a machine shop. They will be able to tell you what it needs.
EddyPei · Registered Joined 2 mo ago · 2 Posts #4 • 2 mo ago do you have all other assy ? trans ? loom, ECU ? complete swap less long block ?
LotusElise · Arouse the DAMPFHAMMER! Joined Oct 13, 2013 · 6,968 Posts #5 • 2 mo ago Sorry guys, the OP wasn't here since he posted this. I will lock this post until the OP is willing to apply to the forum rules for sales.
