Hi all, first post on this forum.
I've been learning about cars and trying to do a different build. I ended up choosing a k20z3 with a toyota e153 5 speed transmission. I had a couple questions. I have read that to use k pro, I need a 02-04 rsx type s harness and ecu to k pro. Will this cause interference with my 5 speed?
Is there another harness I can and should use. Or should I try and use a different SDS all together? Any advice would be helpful on the engine front, as I'm no expert with Honda engines..
