1 - 4 of 4 Posts
Anyone here run a gt3082r turbo on a k20z3 and what was you max power output? Just curious what the gt3082r will produce on k20z3?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Vague question.
Depends on fuel, bolt ons, tuner, all kind of other variables.
Discussion Starter · #3 · (Edited)
will have 1/2 inch feed 3/8 return. And a walbro 450 lph e85 pump. 1200cc injectors but I'm asking what others have made with this turbo. Reason for asking is I can only find info on b series engine. Has anyone ran this turbo on a k series
Well if ya run 2 bar thou it you will see 500 bhp with good cams and like the man says the right bolt on bits n good head work ... as for that fuel pump its good for 400 anymore and wont be man enough... That said you wont be on boost until 6500 rpm with that bigger unit
1 - 4 of 4 Posts
