1 - 3 of 3 Posts
Hello! Just swapped a K20z3 into my EG and car is pretty much in limp mode. Car starts up right away but idles up and down. Go to drive it and only goes to 2.5k rpm and is like bogging. Car is getting fuel. Just calibrated the TPS sensor and installed a new IAC Sensor. Loaded a K20 Itr map through Hondata. Running a Rywire tucked harness rsx type s. Not sure what else to try? HELP
2.5k sounds like the TPS signal is braking up or the VSS sensor signal is incorrect.
In both cases, the ECU applies a very low rev limiter.
Make sure in the software, that the TPS moves 0 to 100% without any steps or glitches.
Log data and make sure the VSS signal does not break up as speed increases or decreases.
1 - 3 of 3 Posts
