I made a breakthrough realization in this
thread over here (sorry again for the threadjack
@SaucerClone).
@Lotus and
@LotusElise made some important distinctions that lead me to believe that my tune is, to be kind, unfinished.
My car has a mildly lumpy idle, which some tinkering with the IACV duty cycle has actually already improved quite a bit. I believe I need to spend a bit of time tinkering with the idle ignition control and idle ignition compensation areas a bit to dial it in further.
My larger issue is that it seems like the tune I have has no adjustments in the areas where I'm having issues...
- Neither of the 6 ignition tables (low or high) has a single adjustment from the "k20a2 factory calibration" map Hondata provides
- The zero degrees low-speed fuel map also has no changes
The car surges badly on/off throttle at low speed (for example, subtle throttle input changes while cruising at 30mph in 4th gear cause the car to lurch pretty badly). Lifting from very low to zero throttle also causes the car to lurch badly. In the discussion above it was called out that too much ignition timing can contribute to this sort of behavior.
If I'm understanding things correctly, it sounds like picking a region like this:
...and adjusting it downwards by a few degrees should help. This may need to be repeated across the 10°, 20°, etc. tables as well depending upon where the car actually is when the bad behavior occurs.
I'm assuming I should probably data log and adjust fuel down here if it also seems to help. Sorry for the crazy noob questions, but I have to start somewhere. I dug up and watched the old training videos Hondata used to help and read some articles on general theory for doing this, but I think I need to pay for one of these various training courses (Evans, etc.) to get more in-depth background.
In the meantime, though, if someone can confirm my proposal above and tell me if I'm on the right track, it'd help my car be more pleasant at low loads.
Full disclosure, I am not crapping on the tuner or the tune. This was done during the winter of 2020/2021 by a local shop willing to take on my job even though it isn't in their usual wheelhouse. The shop did a fantastic job with the fit and finish of the physical pieces. They seem to typically be tuning much newer cars, almost all of which use forced induction, so I assume that they got it running acceptably, tuned it for power to the extent they were comfortable, and called it a day.
--Matt
