1 - 19 of 19 Posts
i have a k20z3 swap in my ek and i'm getting a speed cut at 6000 every time and heres my set up.
swap header
type s throttle body
short ram intake
everything else is stock i am not running kpro at the moment i'm running a PRC ecu
also do not have vss hooked up
fuel pressure is at 54
i have the primary 02 but i don't have the secondary.
car idles at 1400 after warming up
sounds to me like the spool valve isnt working correctly, if you think about it when you hold the rpms your giving the spool valve enough time to build pressure to make vtec engage. i would say change the solenoid or you have a problem with oil pressure.
Discussion Starter · #17 ·
well i was planing on getting a S2000 cluster. I saw on here there was something you could use at radio shack for $5.00 to convert the frequency on the vss . but it would only work on kpro .
1 - 19 of 19 Posts
