1 - 2 of 2 Posts
so, looks like i may dump a z1 into my ep3....
i have a type-s 6spd tranny already...
will the 02-04 tranny match up to the 06 z1?
what wiring harness is necessary to get speedo/fan/tach working properly?
ecu needed? (aside from kpro)
thx guys :D
yes the tranny will work fine
use your stock harness. only thing that wont work is the reverse lockout, which you should already have that issue since u have the 6 spd in there already. or you could use an 02-04 type s harness if u really wanted.
you can get kpro on your stock ecu, but again there would be no reverse lockout. or you could get kpro on an 02-04 type s ecu if u want that function. you could also run a stock 02-04 type s ecu, you would just have to get the immobilizer matched to your key/car by the dealer. you could also use a jdm PRC ecu. the kpro is by far the best option though if u want to get the real potential out of the engine.
1 - 2 of 2 Posts
