Hi guys,
love this forum, so interesting and awesome things to be learned here
I'm prepping for a cylinder head build on my Euro K20Z4 FN2.. Just need some advice as to what would be best or if anything, some recommendations from you guys please. Block will remain unchanged, comp is 11.0:1 from factory.
Current power mods:
- Injen CAI
- Hondata Flashpro
- Bosson Performance Race 4-2-1 header (no cat)
- Bosson Performance 2.5" single exit mandrel bent exhaust (63mm)
- P2R thermal intake manifold gasket
- P2R TB thermal gasket (x2)
- P2R TB metal spacer
- Skunk2 Carbon composite fuel rail
- RRC FD2 intake manifold
- Competition Clutch Ultra-Lightweight Flywheel
My FN2:
Power figures as is: 170.5kw / 226nm
My head build plans:
305-05-0225: Skunk2 K-Series Tuner Series Stage 2 camshaft
310-05-2540: Skunk2 K20 Valve Set, Hi-Comp, Stock Size, DOHC i-VTEC
308-05-0410: Skunk2 K20/K24 DOHC i-VTEC Titanium Retainers
312-05-0010: Skunk2 Spring Base Kit for K20 engines
311-05-5380: Skunk2 K20 Pro-Series Valve Spring Set
304-05-0275: Skunk2 K20 Pro-Series Camgear (EXHAUST)
340-05-0002: Skunk2 K-Series Pro Series Timing Chain Tensioner
14401-K20-000: TODA Heavy Duty Timing Chain, K20
13441-K20-B00: TODA Heavy Duty Balancer Chain, K20
12251-K20-103: TODA High Stopper Metal Head Gasket (0.3mm)
The above is what I am thinking of ordering. Will this setup work and provide decent gains in power and torque? Also waiting for Skunk2 to release their 72mm Drive-By-Wire TB which i will mate up to the 72mm ported RRC mani.
High comp valves from Skunk2 will raise comp ratio by 0.3 - 0.5 points. TODA 0.3mm gasket raises comp by 0.4 points. So effectively I'll be sitting on 11.8:1 give or take, is this enough for optimal stage2 cam usage?
Reliability issues? Valve/Piston clearance issues? Any views and advice guys, please hit me with it!
Regards from Cape Town, South Africa
Renze
Current power mods:
- Injen CAI
- Hondata Flashpro
My FN2:
Renze
