yes it is possible but you have to contact hondata with the serial number from the ecu to see if the ecu you have is compatible to do it... the only problem is that you lose your reverse lock that prevents you from putting it in reverse while the car is going forwardazazel said:is tha posible to reflash a k20a3 ecu in to a other k20a2
thx
