1 - 3 of 3 Posts
i have a k20a3 in my eg, i messed up and bought the wrong conversion harness. i bought a Hasport 99-00 ek conversion harness, so i went a purchased a 00 entire cabin harness, and everything works as it should but
i have no injector pulse. ive used a NOID light so i kno i dont. i do have 12v at both injector wires, and if i use a light tester, with it grounded out i can hit each pin of the injectors and every single one then sprays for as long as i hold the test light grounded out to it.. which i know isnt ideal but
how do i get my injectors to pulse ? should i wire them direct to ecu? would that solve my issue?
sounds like the issue is between the wires from the injector to the ecu or the ecu its self.
do you have any codes?
ohm out the wiring from the injector to the ecu and let us know.
1 - 3 of 3 Posts
