Swapping a K20a3 engine from the Civic Si or Base RSX would be the same procedure as the A or A2 engine.The ECU and Main harness plugs have the same pinout as the A and A2 engines(Minus a few pins such as reverse lockout solenoid on the 6 speeds and dual runner intake manifold control of the base rsx etc..).The wiring woul be very similar and an aftermarket adaptor harness made for an R or S would work for the A3 harness,
The mount brackets are the same,so you would use the same mount kit,the transmission gear select levers are the same,so you can use the same linkage..Im not 100% sure about the civic si intermediate shaft though,but thats a quick enough fix using a type s shaft.
Welcome to the Site!
