Ok guys my engine check light is saying its over heating.
But my Cluster Temp is normal.
yes I don't know the reading might be false. why I think this is because my cluster themp guage is reading normal. I am not trying to fuck up my motor nor my turbo, today I did the following bought two gallon of Type 2 coolant from dealer. Flushed the system like this. Opened the drain valve on the bottom of radiator ran tap water through the radiator. Filled that baby up with Coolant like the helms says. Turn on the car with the cap not on tight. Let the fan go on for two times. shut of the car then add coolant. This looks like didn't solve the problem. I am stumped. Why is the ecu reading its over heating and my guage is reading normal..??
anyone know what is the normal operating temperature. because before I didn't have this problem with this engine over heating...
what you think Hondata. maybe I should try it your way...??
max temp was 228 degrees on the log. what does this indiciate false perharps?
thanks a lot :dance:
