1 - 6 of 6 Posts
Well i have done it again, in the haste of removing the motor out of the rsx months ago i now start getting the throttle cables worked out and i notice that the nut for the throttle body to hold all the springs and such for the cables to the throttle body is missing. I was not the one that removed the cables, otherwise it would have been put right back on. Anyways does anyone have an idea as to the size of the bolt or if acura even supplies this nut. I kinda need it lol. also if anyone has any pictures how everything goes back together that would help tremendously. Thanks in advance.:cool:
No i didn't think it was clear. It looks like i need the nut that holds number 16 on the throttle body its the nut that you have to remove to get the throttle cable disconnected from the throttle body butterfly itself. Does that make sense? i know this is a long shot.:confused: directly accross the tps.
Bump anyone have a picture of it all together i am going to try the nut off of my b18 throttle body i hope it will work. Thanks.
Just run by any auto parts store and get a nut for that, it will be metric.
Also in the future DO NOT remove that nut. All you need to do to remove the cable ends from the rotor is to rotate the rotors fully by hand and line the cable up with the slot and then slide the cables ends out one side, it takes 2 seconds to remove the cables from the TB.
Yea i know how to remove it, i wasn't the one that did, i am learning more and more every day if you want it done right do it yourself. It was one of those saturday afternoon with pizza and beer, whoever wants to come help remove the motor your welcome. So i don't know who removed it.:dance: Yea i will just end up doing that just don't know the size so i figured i would find out here so i don't have to take the throttle body off. But i am just going to do that.
1 - 6 of 6 Posts
