1 - 3 of 3 Posts
if your buyin the full swap, i would say the a2 because if you buy the z1 you still need the a2 harness, a2 ecu, speed sensor converter, and maybe a couple other things. motor for motor i would go with the z1. it is said to have better cams and a few other things than the a2.
I looked at the z1 motor today from a wreck rsx motor was pushed in .. worry about broken bolts...and the a2 has the motor and everything cept shift link ,alterator, and ecu
EDIT-- Found out the differences...in the sticky haha..thanks for your help
1 - 3 of 3 Posts
