1 - 11 of 11 Posts
Up for sale I have a 02-04 k20a2 long block with no accessories, long block has 105++ miles on it, was going to put in my car but i have decided to go another way. Selling bare for 800, im also willing to sale block and head separate...if interested hit me up at 717-332-6912 for a better way of contacting me...im located in north Jersey......also I have a bare k20a2 block which comes with a k20a jdm crank and oem k20a2 pistons and rods.. the block, crank and piston are all in working order, will sale for 350.......I also have the ac compressor, alternator, water pump with housing, starter, wire harness and charger harness, intake manifold, throttle body with all the sensors, shifter box with out the shifter cables, 36mm axles, power steering pump, belt tensioner and fuel rail with injectors, all the parts where taken off the long block when I send it to get painted, okay so if u are interested in the long block with all the accessories I just listen I could sale for 1300....all parts are oem incase you wondering, vin numbers will b shown to does that come down to check the motor, do to a lot of people in the past ask me for vin# and than never even respond back to at least tell me they'll pass or whatever, so therefore I will no longer give the vin out on text, email etc, unless you come in person, I am guaranteen that all parts and long block are in perfect operating conditions. ... https://www.dropbox.com/sc/8n66s449zdmwqxp/JulHX7sGgt
Contact info?
1 - 11 of 11 Posts
