221 - 235 of 235 Posts
Ive read thru this but still confused on the pulley system I would like to keep it as OEM as possible and will also be keeping power steering but not AC and im planning on swappin in a k24. So what pulley system will I be needing to get?
you can run ps and no ac, just buy the right length belt, nothing else is needed.
Ok cool thanks for the info.
couple of more questions I'm planning to do a k2a swap I know I will need the k20 harness but is that plug n play or do I have to custom it to make it work with the 24?
And right now I'm looking at what parts to get etc and I see the cruise control delete kit but I was wondering since they have a kit that includes a gsr throttle cable won't it be the same as my b16 cable cause right now I have a poorman type r in my em1. So in other words I wouldn't need the gsr cable since the b16 should be the same?
Hey awesome job on ur car :)......I'm going to put a k20 into my ek4 but I'm being told that I can't have power steering unless I have special brackets to install it??....could any 1 tell me what brackets I need an where could I get them please.....tanks
i see that you dont have p/s how did you retain the ac and delete ps i would love to do this on my hatch because its hot all the time in cali!. did you just use a ep3 idler pully?
First time using this but I'm wondering I have a 2002 acura rsx premium and a smashed 08 civic si how much work and what do I need to do for this swap to be accomplished
I'm using a PRC ECU, getting fuel to my rail but nothing through the injectors. Can you suggest anything i can do?
00 EK
PRC ECU
Sparxx Harness
Type R engine harness
k24 engine
