201 - 220 of 235 Posts
ok so i have a few questions 1 where did u get all the fuel lines and fittings from?? and how much?? also im doing a boosted k24 swap and i know there pritty much the same to put in but is there any thing that needs to be relocated?? like the altanater or ne thing like that also how hard was it to install the pnp hasport harness?? do me a favor and email me at [email protected] so i have someone i can talk to about doin my swap and because im in iraq and not all the bases will let u get on these site blocked for some reason thanks
by the way i think this is one of the most helpful post for a k swap ive seen yet
I did it for people to use :) very glad to hear it has helped you!!
Hi, I don't know if I missed this info so please bear with me but what transmission did you use with your swap? I will be doing the swap soon using a K24 Motor in my RHD 97 Hatchback EK and I am currently shopping for a suitable tranny to drop in :) The car will be a daily driver but will drag on the weekends!! :)
Also, How many harnesses will I need to buy to do the conversion? Will it be the same amount of harnesses as for a LHD model? Can I get them all from one Dealer?
Thanks for your help and GREAT!!! job with the write up/photos.
Hey man u need a 02 -04 rsx tranny u can usee the 05 06 but thsere a pa
In in the ases due 2 thse vvs a also u will need an 02 - 04 rsx engine harness and charge harneses and pnp conversion harneses ne questions pm me
Hi, Does the tranny have to be the type S and would it be 5 or 6 speed? I am sourcing one from ebay. I think Hasport sells the conversion harness but I can only find used engine bay and charge harnesses on ebay for the K20. Can they also work for the K24? Thanks
Don't have 2 be a type s no I beleave u can use a ep3 si tranny also but as for the tranny there are plenty of ppl selling trannys on here go to parts for sale and look around that's what I did and as for the pnp harness yes hasport makes those as well as a few other companys and for the type s charge and engine harness yes the type s will work for k24 and again u can either by new from honda or by them from off this site also plenty of ppl gettin rid of stuff like that on here
Hi, Do you know what the part numbers are for the following parts?
: Pedal Assy Brake $38.36
: Pedal Assy Clutch $40.72
: Clutch Pedal Bracket $17.20
: OEM Master Cylinder $98.07
: Clutch Fluid Tank $5.17
Thanks
Thanks
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry2=2000&catcgry3=2DR+SI&catcgry4=KA5MT&catcgry5=CLUTCH+MASTER+CYLINDER+%281%29
46920-S04-A01 005 001 MASTER CYLINDER ASSY., CLUTCH list price 124.65 majestic price 88.50
46972-S01-A01 013 001 TANK, CLUTCH FLUID list 3.72 majestic price 2.64
Part No. Illust. No. Reqd.Qty. Description Color List Price Our Price
17800-S01-A10 001 001 PEDAL, ACCELERATOR 21.82 15.49 Qty:
17812-SA7-010 002 002 WASHER, ACCELERATOR PEDAL 1.77 1.26 Qty:
17814-SD4-670 003 001 SPRING, ACCELERATOR PEDAL 3.62 2.57 Qty:
17816-SK7-000 004 001 COVER, ACCELERATOR PEDAL 6.87 4.88 Qty:
17856-S01-A30 005 001 ARM, AUTO CRUISE 18.18 12.91 Qty:
17858-SM4-000 006 002 BUSH, CENTER 0.98 0.70 Qty:
17863-SR3-J30 007 001 SPRING, AUTO CRUISE 3.12 2.22 Qty:
17910-S04-L02 008 001 WIRE, THROTTLE (NIPPON CABLE) 23.78 16.88 Qty:
17921-SA4-730 009 001 SEAL, THROTTLE CABLE 4.88 3.46 Qty:
17932-S04-A00 013 001 CLAMP, THROTTLE WIRE 13.13 9.32 Qty:
35710-SE3-A01 015 001 SWITCH ASSY., CLUTCH (INHIBITER) 45.05 31.99 Qty:
36750-S04-003 016 001 SWITCH ASSY., STOP & CRUISE 42.73 30.34 Qty:
36760-SE0-003 017 001 SWITCH ASSY., CLUTCH (TEC) 28.23 20.04 Qty:
46500-S04-A10 018 001 PEDAL ASSY., BRAKE 57.40 40.75 Qty:
46504-ST5-300 020 004 BUSH, PEDAL 3.10 2.20 Qty:
46505-SA5-000 021 003 PAD, PEDAL STOPPER 2.15 1.53 Qty:
46505-SA7-000 022 001 PAD, PEDAL STOPPER 4.07 2.89 Qty:
46530-SR3-000 023 001 SPRING ASSY., PEDAL RETURN 5.75 4.08 Qty:
46535-SM4-000 024 002 COLLAR, PEDAL 6.53 4.64 Qty:
46545-SH3-000 026 002 COVER, PEDAL 8.58 6.09 Qty:
46590-S01-A30 027 001 BRACKET, PEDAL 35.20 24.99 Qty:
46907-SR3-010 028 001 SPRING, CLUTCH ASSISTANT 6.80 4.83 Qty:
46910-SR3-J00 029 001 PEDAL, CLUTCH 60.93 43.26 Qty:
46911-SD4-930 030 001 BUSH, PEDAL PIN 2.85 2.02 Qty:
46981-SR3-930 031 002 BUSH A, CLUTCH ASSISTANT 4.00 2.84 Qty:
46982-SR3-930 032 001 BUSH B, CLUTCH ASSISTANT 3.57 2.53 Qty:
46990-SR3-A00 033 001 BRACKET, CLUTCH PEDAL 77.57 55.07 Qty:
46991-SR3-010 034 001 BRACKET, FOOTREST 17.93 12.73 Qty:
92201-10070-0J 036 002 BOLT, HEX. (10X70) 1.28 0.91 Qty:
93402-06012-08 037 001 BOLT-WASHER (6X12) 0.77 0.55 Qty:
93404-08016-08 038 002 BOLT-WASHER (8X16) 0.90 0.64 Qty:
93405-06020-07 039 002 BOLT-WASHER (6X20) 0.87 0.62 Qty:
94001-10080-0S 040 001 NUT, HEX. (10MM) 0.73 0.52 Qty:
94002-10080-0S 042 001 NUT, HEX. (10MM) 0.73 0.52 Qty:
94002-12080-0S 043 001 NUT, HEX. (12MM) 0.68 0.48 Qty:
94050-10080 044 002 NUT, FLANGE (10MM) 0.92 0.65 Qty:
94102-10800 046 002 WASHER, PLAIN (10MM) 0.78 0.55 Qty:
94201-25180 047 002 PIN, SPLIT (2.5X18) 1.15 0.82 Qty:
95701-06012-08 048 001 BOLT, FLANGE (6X12) 0.85 0.60 Qty:
46905-SK7-000 049 001 STOPPER, CLUTCH PEDAL 6.35 4.51 Qty:
17931-S01-A20 050 001 STAY, THROTTLE WIRE
i have a 99 ek that im swapping a k20a2 into. im kinda confused on which mounts i should use and if using an eg subframe will make a big difference? i already have an eg subframe that i got from my boy. do i use it and buy ekk2 mounts?
hey so i was wondering, im trying to go oem on my axels and one axel came out to be short. so i was wondering if this is confirmed type s inners and a 92+ shaft with b series outers, and what side prelude shaft would that be/
Yes and you Need the ekk2 swap axles.
Is this list similar for the k24a2?
Im planning on doing a k24 swap into my ek hatch and its time to start stocking up on parts, i need to start doing this swap soon, i will be going with the ekk2 mounts and eg subframe with power steering.
I want to put the engine in the car in stock form for now then build it down the line.
I need a COMPLETE parts list and also what ecu can i use for this motor in stock form, will get a better ecu once built.
Can someone point me in the right direction.
nice write up. doing a rsx-s swap in my 99 lx 4-dr. I wish you gave more detail with the wiring harness. I did a 5-lug spindles off 00 crv and 36mm rsx-s axles fit with no problems or modifications. The rsx-s calipers/rotors/hubs fit with no problem on crv spindles. :dance:
" media="(max-width: 640px)"> " media="(max-width: 960px)"> " media="(max-width: 1920px)">
Ok so after reading all the pages I have made up my mind to go with ekk1 mounts for the simplicity of not having to swap the eg front suspension components. And I'll be running power steering but I'll be using an rsx pump and run custom lines to the rack and reservoir. Now has anyone run into issues installing the rbc mani while using the ekk1 mounts? Im looking into gettin a half size radiator and tucking it and also tucking the power steering reservoir. What brand should I get for the radiator and do they have custom overflow tanks that allow to be tucked? Thanks for any help
Also has anyine used the avid motor mounts and have any reviews since they are badically $100 cheaper?
Your in luck. I have avid ekk1 mounts in my ek. look up top picture, same ones and Im selling them right now $250 shipped, worked great in my ek. But I just got my hybrid racing ekk2 mounts. and completely converting my engine bay to integra steering rack sub-frame etc. I do all the work my self, Its my hobby. Also I can sell you the oem rsx-s left axle and my "secret" oem rignt axle 36mm for 5 lug that worked perfect with ekk1 avid mounts for $260 pair. also have rsx-s power steering pump can trow in for free if you buy axles and mounts. here's a video with those mounts/axles in action: http://www.youtube.com/watch?v=LZxeQBchvqs&feature=related
and one more in the rain.lol: http://www.youtube.com/watch?v=cOWmbicGun8&feature=related
posted message in your profile
Ive read thru this but still confused on the pulley system I would like to keep it as OEM as possible and will also be keeping power steering but not AC and im planning on swappin in a k24. So what pulley system will I be needing to get?
