no no no... the head HAS to match the ecu... you will cause major internal problems if you do not have them matched. the computers are diffrent for a reason, diffrent compression ratios, fuel ratio's, diffrent vtec, diffrent cams.. everthing in the head is diffrent...
just match the head with the ecu... unless it is a k20a with a kproed a2 ecu
