1 - 16 of 16 Posts
From this link, I got an idea to put K20a with automatic transmission.
I talk to babyk for a while and decided to do.
K20a block
My old automatic gear box.
K20a block and gearbox before build up and after.
Discussion Starter #2
Everythings perfect fit
Except this
But no problem. Cut off a little bit for perfect fitting.
I use the original ECU with automatic transmission and reflash with Civic typeR's fuel map via Hondata FlashPro.
thanks to babyk for tunning.
Banned
2007+ K20A, did you get a deal on the engine?
Discussion Starter #8 (Edited)
Interesting. What chassis did you put this in and are you going to dyno it to see how much hp it makes with the auto?
My 2006 civic (FD) come with K20z2 and automatic transmission.
did you dyno it?
Coming soon. Nearest is 600 km from here.
Next trip to Bangkok, I will go to dyno.
2006 civic FD1, K20z2 engine, Automatic transmission with paddle shift.
k20a.orgy
:up:
Nice imagine a 4 door DC with that set up
Banned
Z2 is VERY similar to A3 in power as I recall. Doesn't the Canadian base Acura CSX come with a Z2?
Yup the csx comes with the z2 it's almost identical power to an a3. My buddy has one till I looked into it I always thought it was a A3.
Banned
Information about the Z2 is not as widespread as an A3, I'm curious to know if it is a 2 lobe rocker like the A3 like an i-VTEC-E?
Banned
NICE:up:
Discussion Starter #15
Parts moved from z2.
- All pulleys and belt. (K20a use oil power steering, K20z2 use EPS)
- EGR valve
- K20z2 harness
K20a's parts use.
- All sensors. Some sensors have different plug, modify them.
- Water pump.
- IM and TB
- Generator (K20a use 55A, K20z2 use 45A)
Must do.
- Transmission Oil Cooler
- New header. (K20a's header hit to EPS motor)
1 - 16 of 16 Posts
