1 - 5 of 5 Posts
If I'm not mistaken, the Z1 cams have the same profile as the type r cams. I know u can probably find those for a good deal but if you have the money there are some pretty good cams out there that are still relatively mild and will make more power than Z1/ type r cams
If I'm not mistaken, the Z1 cams have the same profile as the type r cams. ...
...and revised, retarded centerline at the exhaust cam (about 4° to 6°, depending on reading of the measurement)
...but if you have the money there are some pretty good cams out there that are still relatively mild and will make more power than Z1/ type r cams
OEM camshaft quality is of no question, aftermarket...depends :D
1 - 5 of 5 Posts
