cheers thats what I thought but I thought I'd see what else everyones temp runs at..
I think it might be from the Cam split at high revs.. To much advance for the exhaust cam since the Inlet cam is retarded 25 degree at rest.. Might have to lock it and see if that makes a differnce.. I will try and sort it out this week and get back on and see how it worked..
Also the only hondata thing on my car is the heatsheild gasket, I run a different ECU.. I might get the temp turned down on it to and get a new low temp thermostat and see if that also helps..
