1 - 5 of 5 Posts
Super Moderator
2002 DC5 Type S
This is not 100% complete, there are more figures to add, correct, and editing to do. Enjoy.
This is DC5 based. The DC5 Type R will most likely fall into the same.
Motor vehicle Font Line Auto part Engineering
#8 Special Flange Bolt (10x77) PN# (90161-S7C-000) Qty. 1
10 x 1.25mm | 59 N.m ( 6.0 kgf-m - 43 lbf-ft )
#9 Flange Bolt (10x20) PN# (90163-S5A-000)
#9 Flange Bolt (10x20) PN# (90163-S5A-000) Qty. 1
#10 Flange Bolt (12x90) PN# (90164-SH3-010) Qty. 1
12 x 1.25mm | 64 N.m ( 6.5 kgf-m - 47 lbf-ft )
#11 Flange Bolt (12x54) PN# (90165-S7C-000) Qty. 1
#12 Flange Bolt (12x84) PN# (90166-S7C-000) Qty. 3
#13 Flange Bolt (12x88) PN# (90167-S5A-010) Qty. 1
12 x 1.25 | 64 N.m ( 6.5 kgf-m - 47 lbf-ft )
** Always replace. **
#14 Flange Bolt (12x35) PN# (90168-S5A-000) Qty. 3
12 x 1.25mm | 64 N.m ( 6.5kgf-m - 47 lbf-ft )
#15 Flange Bolt (12x45) PN# (90170-S30-000) Qty. 1
12 x 1.2 5mm | 54 N.m ( 6.5 kgf-m - 47 lbf-ft )
#16 Flange Nut (12mm) PN# (90371-SR3-000) Qty. 1
6 x 1.0mm | 12 N.m ( 1.2 kgf-m - 8.7 lbf-ft )
#18 Flange Nut (12mm) PN# (9405
12 x 1.25mm | 54 N.m ( 5.5 kgf-m - 40 lbf-ft )
#23 Spindle Nut (24mm) PN# (90305-SD4-003) Qty. 2
K20A3 181 N.m ( 18.5 kgf-m - 134 lbf-ft )
K20A2 245 N.m ( 25.0 kgf-m - 181 lbf-ft )
#27 Washer-Bolt (8x25) PN# (93406-08025-08) Qty. 3
8 x 1.25mm | 22 N.m ( 2.2 kgf-m - 16 lbf-ft )
Motor vehicle Font Engineering Auto part Automotive super charger part
#5 Special Bolt (10x28) PN# (90002-PNA-000) Qty. 1
26.5 - 36.3 N.m ( 2.7 - 3.7 kgf-m - 19.5 - 26.8 lbf-ft )
#6 Bolt (10x75) PN# (90008-PNA-000) Qty. 3
10 x 1.25mm | 44 N.m ( 4.5 kgf-m - 33 kgf-m )
#7 Special Bolt (8x105) PN# (90025-PNA-000) Qty. 1
8 x1.25 | 22 N.m ( 2.2 kgf-m - 16 lbf-ft )
#8 Special Bolt (10x50) PN# (90027-PND-A00) Qty. 1
10 x 1.25mm | 44 N.m ( 4.5 kgf-m - 33 lbf-ft)
#9 Stud Bolt (12x91) PN# (90043-PZD-A00) Qty. 1 or 2
#11 Flange Nut (6mm) PN# (94050-06080) Qty. 1
8 N.m ( 0.8 kgf-m - 6 lbf-ft )
#12 Flange Nut (6mm) PN# (94050-06080) Qty. 1
8 x 1.25mm | 9 N.m ( 0.9 kgf-m - 7 lbf-ft )
#13 Flange Bolt (8x45) PN# (95701-08045-08) Qty. 2
8 x 1.25mm | 22 N.m ( 2.2 kgf-m - 16 lbf-ft)
#13 Flange Bolt (8x45) PN# (95701-08045-08) Qty. 1
#14 Flange Bolt (8x70) PN# (95701-08070-08) Qty. 1
55 N.m ( 5.6 kgf-m - 41 lbf-ft )
#15 Flange Bolt (12x60) PN# (95701-12060-08) Qty. 4
#16 Flange Bolt (12x85) PN# (95701-12085-08) Qty. 1
White Font Line Urban design Engineering
#2 Sealing Bolt (20mm) PN# (11106-PNA-300) Qty. 1
39 N.m ( 4.0 kgf-m - 29 lbf-ft )
#3 Sealing Bolt (28mm) PN# (11106-PR4-013) Qty. 1
#10 Oil Jet Bolt PN# (15290-PRA-000) Qty. 4
16 N.m ( 1.6 kgf-m - 12 lbf-ft )
#13 Knock Sensor PN# (30530-PRB-A01) Qty. 1
31 N.m ( 3.2 kgf-m - 23 lbf-ft )
#14 Oil Pressure Switch (Tec) PN# (37240-PTO-014) Qty. 1
18 N.m ( 1.8 kgf-m - 13 lbf-ft ) gasket sealant to threads
#15 Drain Plug Bolt (28mm) PN# (90001-PM3-003) Qty. 1
#17 Flange Bolt (11x95) PN# (90006-PNA-003) Qty. 10
29 N.m ( 2.2 kgf-m - 16 lbf-ft )
Then one additional 56 degree turn in sequence
#19 Al Oil Pan (14mm) PN# (90009-R70-A00) Qty. 1
39 N.m (4.0 kgf-m - 29 lbf-ft )
#30 Oil Pump Baffle Plate Bolt (6x14) PN# (95701-06014-08)
#32 Flange Bolt (6x30) PN# (95701-06030-08) Qty. 3
#33 Flange Bolt (8x35) PN# (95701-08035-08) Qty. 16
#34 Flange Bolt (8x50) PN# (95701-08050-08)
#35 Bottom Transmission Flange Bolt (10x50) PN# (95701-10050-08) Qty. 2
12 x 1.25mm | 64 N.m ( 6.5 kgf-m -47 lbf-ft )
#36 Flange Bolt (6x32) PN# (95701-06032-08) Qty. 15
Product Motor vehicle Font Auto part Engineering
#9 Lower Drain Plug Bolt (14mm) PN# (90081-PB6-000) Qty. 1
#10 Sealing Bolt (32mm) PN# (90081-PPP-000) Qty. 1
#11 Stud Bolt (12x83.8) PN# (90380-S10-000) Qty. 2
** Flush down **
#13 Drain Bolt (20mm) PN# (92800-20000) Qty. 1
44 N.m ( 4.5 kgf-m - 33 lbf-ft )
#16 Flange Bolt (8x20) PN# (95701-08020-08) Qty. 3
6 x 1.0mm | 9.8 N.m ( 1.0 kgf-m - 7.2 lbf-ft )
#17 Flange Bolt (8x40) PN# (95701-08040-08) Qty. 15
8 x 1.25mm | 27 N.m ( 2.8 kgf-m - 20 lbf-ft )
#18 Flange Bolt (8x65) PN# (95701-08065-08) Qty. 2
Motor vehicle Font Art Auto part Automotive design
#6 Back Light Switch Assembly (Gray) (Tokai) PN# (28700-PHR-003)
29 N.m ( 3.0 kgf-m - 22 lbf-ft )
#12 Needle Set Plate Flange Bolt (6x12) PN# (95701-06012-08) Qty.
6 x 1.0mm | 12 N.m ( 1.2 kgf-m - 9 lbf-ft )
#13 Flange Bolt (10x25) PN# (95701-10025-08) Qty. 1
Font Motor vehicle Auto part Circle Drawing
#9 Speed Sensor Assembly Flange Bolt (8x25) PN# (95701-08025-08) Qty. 1
Motor vehicle Automotive lighting Font Auto part Engineering
#8 Interlock Bolt PN# (24433-PH8-000) Qty. 1
#19 Hex Bolt (8x24) PN# (90029-611-010) Qty. 1
#23 Flat Screw (6x14) PN# (93600-06014-0H) Qty. 1
#26 Flange Bolt (6x16) PN# (95701-06016-08) Qty. 3
6 x 1.0mm | 12 N.m ( 1.2 kgf-m - 8.7 lbf-ft)
#27 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 2
12 N.m ( 1.2 kgf-m - 9.0 lbf-ft )
#28 Flange Bolt (6x30) PN# (95701-06030-00) Qty. 2
Body jewelry Font Auto part Circle Jewellery
#5 Special Bolt (11mm) PN# (90017-PPP-000) Qty. 10
11 x 1.0mm | 121 N.m ( 12.3 kgf-m - 89 lbf-ft )
Bicycle part Font Auto part Drawing Line art
#7 Detent Ball Spring Setting Screw PN# (24519-PB6-000) Qty. 3
#8 Special Bolt (6x22.5) PN# (90028-PB6-010) Qty. 2
Font Line Parallel Auto part Technical drawing
#21 Hex Bolt (10x1.25) PN# (90102-SF1-000) Qty. 1
10 x 1.25mm | 39 N.m ( 4.0 kgf-m - 29 lbf-ft )
#22 Flange Bolt (10x37) PN# (90165-SE0-000) Qty. 2
Super Moderator
2002 DC5 Type S
Discussion Starter · #2 ·
Motor vehicle Font Automotive design Automotive exterior Auto part
#1 PCV Valve Assembly PN# (17130-PRB-A01) Qty. 1
Font Auto part Engineering Cylinder Drawing
#4
#14 Tensioner Pivot Bolt PN# (90003-PNA-000) Qty. 1
#15 Flange Bolt (12x47) PN# (90032-PNA-000) Qty. 1
113 N.m ( 11.5 kgf-m - 83 lbf-ft )
#16 Flange Bolt (10x32) PN# (90042-PNA-003) Qty. 1
63 N.m ( 7.0 kgf-m - 51 lbf-ft )
#18 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 3
#19 Flange Bolt (6x30) PN# (95701-06030-08) Qty. 2
Font Parallel Engineering Drawing Auto part
#4 Special Bolt (6x33.6) PN# (90021-PNA-000) Qty. 1
DISCONTINUED PRODUCT
#5 Measure distance b/t chain case surface & oil seal
33.0 - 33.7mm ( 33.0 - 33.7 inches )
#8 Flange Bolt (6x14) PN# (95701-06014-08) Qty. 3
#9 Special (6x20.5) (Guide) Bolt PN# (90028-PNB-003) Qty. 1
#10 Flange Bolt (6x30) PN# (95701-06030-08) Qty. 12
6 x 1.0mm | 12 N.m (1.2 kgf-m - 8.7 lbf-ft )
Automotive tire Font Rim Bicycle part Automotive wheel system
#6 K20a2 Flywheel Bolts (12mm) PN# (90011-PNA-B00) Qty. 8
12 x 1.0mm | 118 N.m ( 12.0 kgf-m - 87 lbf-ft )
#7 Twelve Point (8mm) Bolt (Tokai Trw) PN# (90034-689-000) Qty. 6
25 N.m ( 2.6 kgf-m - 19 lbf-ft)
#8 Flange Bolt (6x12) PN# (95701-06012-08) Qty. 2
6 x 1.0mm | 12 N.m ( 1.2 kgf-m - 9.0 lbf-ft )
Font Auto part Schematic Circle Event
# Clutch Master Cylinder Mounting Flange Bolts Qty. 2
13 N.m ( 1.3 kgf-m - 9.4 lbf-ft )
#25 Washer-Bolt (6x12) PN# (93403-06012–08) Qty. 1
#26 Clutch Line Bracket Flange Bolt (6x16) PN# (93403-06016-08) Qty. 2
#29 Clutch Slave Cylinder Flange Bolts (8x30) PN# (90106-S7A-E00) Qty. 2
8 x 1.25mm | 24 N.m ( 2.4 kgf-m - 17 lbf-ft )
Motor vehicle Font Engineering Auto part Parallel
#7 Head Cover Bolt A PN# (90011-003) Qty. 4
8mm | 22 N.m ( 2.2 kgf-m - 16 lbf-ft )
#8 Head Cover Bolt B PN# (90012-PNA-003) Qty. 1
#11 Flange Bolt (6x16) PN# (95701-06016-08) Qty. 2
#12 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 2
6mm | 12 N.m ( 1.2 kgf-m - 8.7 lbf-ft )
#13 Flange Bolt (6x32) PN# (95701-06032-08) Qty. 1
#14 Flange Bolt (8x90) PN# (95701-08090-08) Qty. 14
#15 Flange Bolt (8x110) PN# (95701-08110-08) Qty. 1
#16 Sealing Bolt (10mm) PN# (90083-PNA-000) Qty. 1
20 N.m ( 2.0 kgf-m - 14 lbf-ft )
Font Engineering Parallel Auto part Machine
B-33-60 P.S. Supply Hose Bracket Flange Bolt
#10 Plug Hole Coil Cover Bolt A PN# (90013-PNC-010) Qty. 2
#11 Plug Hole Coil Cover Bolt B PN# (90014-PNC-020) Qty. 2
6 x 1.0mm | 9.8 N.m ( `.0 kgf-m - 7.2 lbf-ft )
#13 Hex Cap Nut (6mm) PN# (90207-RAA-A00) Qty. 4
#14 Cap Nut (6mm) PN# (90213-PH3-000) Qty. 6
** In 2-3 equal steps following sequence ** Upload sequence **
* upload images of tq sequence & removal *
Gesture Font Auto part Automotive exterior Drawing
#5 Special Flange Bolt (6x38) PN# (90102-PND-000) Qty. 2
#6 Flange Bolt (6x16) PN# (95701-06016-08) Qty. 2
Hand Arm Human body Jaw Organism
#6 Washer Bolt (10x22) PN# (90005-P0A-000) Qty. 1
10 x 1.25mm | 44 N.m ( 4.5 kgf-m - 33 lbf-ft )
#7 Special Bolt (10x22) PN# (90010-PE2-900) Qty. 2
#8 Washer Bolt (8x14) PN# (90015-PTO-J00) Qty. 2
#9 Self-Lock Nut (10mm) PN# (90212-SA5-003) Qty. 2 typical oem pattern
#11 Flange Bolt (8x22) PN# (95701-08022-04) Qty. 2
8 x 1.25mm | 22 N.m (2.2 kgf-m - 16 lbf-ft )
#12 Flange Bolt (10x30) PN# (95701-10030-08) Qty. 3 typical oem pattern
Font Cylinder Engineering Parallel Gas
#1 K20a3 = IZFR611 (NGK) & SKJ20DR-M11 (Denso)
#1 K20a2 = IFR7G-11K (NGK), IFR7G-11KS (NGK), SK22PR-M11, SK22PR-M11S (Denso)
#1 K20a2 = IFRK7G-11KS (NGK) & SK22PR-M11S (Denso)
25 N.m ( 2.5 kgf-m - 18 lbf-ft )
#1 IFR7G-11KS (NGK) & SK22PR-M11S (Denso)
#4 Flange Bolt (6x25) PN# (95701-06025-08) Qty. 2 ** typical oem pattern **
Super Moderator
2002 DC5 Type S
Discussion Starter · #3 · (Edited)
K20a/K20a2/K20a3/K20Z1 Engine
Auto part Font Art Machine Drawing
#5 Pulsation Damper Assembly PN# (16680-PZA-L01) Qty. 1
#18 Stud Bolt (8x22) PN# (92900-08022-0B) Qty. 2
#19 Stud Bolt (8x35) PN# (92900-08035-1B) Qty. 2
#20 Flange Nut (8mm) PN# (94050-08080) Qty. 2
#21 Flange Bolt (6x12) PN# (95701-06012-08) Qty. 1
#22 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 6
#23 Flange Bolt (8x20) PN# (95701-08020-08) Qty. 4
Super Moderator
2002 DC5 Type S
Bicycle part Font Auto part Engineering Automotive exterior
#8 Sealing Bolt (18mm) PN# (15233-PC6-000) Qty. 1
39 N.m ( 4.0 kgf-m - 29 lbf-ft)
#9 Engine Oil Filter PN# (15400-PLM-A02)
** fresh oil to O-ring/ hand flush/ hand tighten ¾ clockwise
#11 Oil Cooler Center Bolt PN# (15560-PCX-004) Qty. 1
** Install two 20 x 1.5mm nuts @ 74 N.m ( 7.5 kgf-m - 54 lbf-ft )
#12 Chain Guide Bolt PN# (90004-PNA-000) Qty. 2
#13 N/A Yet
#17 Flange Bolt (6x16) PN# (95701-06016-08) Qty. 3
#19 Flange Bolt (6x25) PN# (95701-06025-08) Qty. 1
#20 Flange Bolt (6x45) PN# (95701-06045-08) Qty. 2
#21 Flange Bolt (8x50) PN# (95701-08050-08) Qty. 1
#22 Flange Bolt (8x75) PN# (95701-08075-08) Qty. 1
Font Auto part Circle Illustration Bicycle part
#5 Power Steering Pulley Nut PN# (90305-PAA-A01) Qty. 1
#13 Pressure Control Valve Cap & (16.7 x 1.8mm) O-Ring
49 N.m ( 5.0 kgf-m - 36 lbf-ft )
#14 Pump Housing Cap & (13x1.9mm) O-Ring
29 N.m ( 3.0 kgf-m - 1.9 lbf-ft )
#18 Flange Bolt (8x35) PN# (91350-PLA-003) Qty. 4
8 x 1.25mm | 20 N.m ( 2.0 kgf-m - 14 lbf-ft )
#19 Inlet Flange Bolt (6x20) PN# (91350-P8C-A01) Qty. 1
11 N.md ( 1.1 kgf-m - 8 lbf-ft )
#20 Flange Bolt (8x45) PN# (95701-08045-08) Qty. 2
Motor vehicle Font Line Automotive tire Auto part
#5 Connecting Rod Bolt PN# (13204-PRB-A01) Qty. 8
K20A3 = 20 N.m ( 2.0 kgf-m - 14 lbf-ft )
K20A2 = 29 N.m ( 3.0 kgf-m - 22 lbf-ft )
#15 Washer-Bolt (16x49) PN# (90017-PCX-013)
Font Auto part Drawing Art Line art
#10 Flange Bolt (6x12) PN# (90001-PEL-003) Qty. 2
#11 Screw-Washer (5x12) PN# (93892-05012-08) Qty. 2
2 N.m ( 0.2 kgf-m - 2 lbf-ft )
Also works for Front Brake (Type-S) 93892-05012-08
#12 Screw-Washer (5x20) PN# (93892-05020-08) Qty. 1
#13 Screw-Washer (5x25) PN# (93892-05025-08) Qty. 2
3.5 N.m ( 0.35 kgf-m - 2.5 lbf-ft )
#14 Flange Nut (8mm) PN# (94050-08080) Qty. 2
#15 Flange Bolt (8x40) PN# (95701-08040-08) Qty. 2
Product Font Circuit component Auto part Engineering
#9 VTC Solenoid Bolt PN# (15835-PNA-003) Qty. 1
#13 Valve Timing Oil Pressure Switch Assembly PN# (37250-PRB-A01)
#14 Washer-Bolt (11x155) PN# (90005-PNA-003) Qty. 1
#15 Stud Bolt (10x39.5) PN# (90026-PNA-003) Qty. 1
#17 Stud Bolt (8x32) PN# (92900-08032-1B) Qty. 1
#19 Flange Bolt (6x10) PN# (95701-06010-08) Qty. 1
#20 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 2
#21 Flange Bolt (6x55) PN# (95701-06055-08) Qty. 3
#22 Flange Bolt (8x16) PN# (95701-08016-08) Qty. 2
Font Auto part Drawing Engineering Line art
#12 Tube Joint PN# (19500-PRB-A00)
#19 Water Temperature Sensor (Keihin) PN# (37870-PNA-003)
#20 Bolt (10x105) PN# (90022-PRB-A01) Qty. 1
#21 Special Bolt (6x19) PN# (90050-PNA-003) Qty. 3
#22 Special Bolt (6x28) PN# (90051-PNA-000) Qty. 3
#26 Drain Plug Bolt (14mm) PN# (92800-14000) Qty/ 1
#27 Stud Bolt (10x60) PN# (92900-10060-0B) Qty. 1
#28 Washer-Bolt (6x12) PN# (93404-06012-07) Qty. 1
6 x 1.0mm | 11 N.m ( 1.0 kgf-m - 7.2 lbf-ft )
#29 Flange Nut (10mm) PN# (94050-10080) Qty. 1
#32 Flange Bolt (6x20) PN# (95701-06020-08) Qty. 2
#33 Flange Bolt (6x25) PN# (95701-06025-08) Qty. 8
#34 Flange Nut (8mm) PN# (94050-08080) Qty. 1
#35 Flange Bolt (10x105) PN# (95701-10105-08) Qty. 2
#38 Stud Bolt (8x15) PN# (90001-PRB-A00) Qty. 1
Font Jewellery Auto part Drawing Illustration
#13 Tappet Adjusting Nut PN# (90296-PT0-004) Qty. 16
* insert valve lash sequence *
Motor vehicle Font Bicycle part Auto part Automotive tire
#12 Pulley Lock Nut PN# (31142-PD1-004)
Font Line Engineering Auto part Parallel
#13 Special Flange Bolt (6x163) PN# (90001-PNA-003) Qty. 1
#14 Special Bolt-Washer (6x35) PN# (90029-PHM-000)
6 x 1.0mm | 12 N.m ( 1.2 kgf-m- 8.7 lbf-ft )
#15 Bolt- Washer (5x28) PN# (90091-P36-000) Qty. 1
6 x 1.0mm | 3 N.m ( 0.3 kgf-m - 2 lbf-ft )
#16 Flange Nut (6mm) PN# (94050-06080) Qty. 1
#17 Flange Bolt (6x30) PN# (95701-06030-08) Qty. 3
Font Line Art Parallel Drawing
#12 Thermo (A-93) Switch Assembly (Nippon Thermostat) PN# (37760-P00-003)
#16 Bolt-Washer (6x16) PN# (90042-PAA-A01) Qty. 4
6 x 1.0mm | 7 N.m ( 0.7 kgf-m - 5 lbf-ft )
** Reserve Tank Flange Bolts 6 x 1.0mm | 12 N.m ( 1.2 kgf-m - 8.7 lbf-ft )
Super Moderator
2002 DC5 Type S
2002-2004 K20A2 DC5 Type S
#19 Gear Box Mounting Bolt PN# (90108-S5A-000) Qty. 2
10 x 1.25mm | 61 N.m ( 6.2 kgf-m - 45 lbf-ft )
#21 Flange Nut (10mm) PN# (90450-S6M-020) Qty. 1
#22 Flange Nut (10mm) PN# (90450-S6M-000) Qty. 2
#25 Flange Bolt (8x25) PN# (90801-S5A-000) Qty. 6
24 N.m ( 2.2 kgf-m - 16 lbf-ft )
#26 Hex Nut (12mm) PN# (94030-12280) Qty. 2
Product Font Line Auto part Engineering
#9 Rack Guide Screw PN# (53414-S04-003)
#18 Rack End Plug PN# (53456-S5A-003)
34 N.m ( 3.5 kgf-m - 25 lbf-ft )
#20 Lock Nut PN# (53458-S50-003)
#38 Flange Bolt (12x40) PN# (90455-S5A-003)
1 - 5 of 5 Posts
