apparrently, the EG meter console cannot be used, u'll have to change to the DC5 meters(speedo, temp, RPM piece)... and it is not sure if the DC5 one can fit..!! but the problem can be fixed if u buy the harness from hasport which means u'll be using the original EG meter console...!!anyway.. at the same time.. EG is better fitting than EK due to the fact that the drive shaft will be straight... in an EK, it is at an angle so when u do a full steering lock turn.. u cannot step on it or it will disengage.... plus.. on an EG u can use the DC5 radiator which is a bigger piece but ur a/c fan will be mounted in front of the radiator due to restricted space..!!
