1 - 4 of 4 Posts
hey everyone. i have 5000 to spend on a swap.. a full swap, including exhaust, intake, mounts, everything. i was told at one point:
i think i can definately do a k20 type S swap for 5500.
I have seen multiple k20 type S swaps for 3000-3500 complete. Average prices needed for completeing the swap are:
Mount kit 500
Header 4-1 equal length 675( and if the 04 Accord header will work then this price will be much lower)
pnp harness 350
SS fuel lines and Guage 130
clutch lines 50
Str fuel rail 180
axels 300
and ecu immoblizer removed.Price depends on who does it.
There is your k20 swap for 5500.
can anyone confirm this? is that everything i need to drop a k series into a del sol?
i know a decent amount about swaps, but never looked into k series, espically swapping one into a sol.
thanks to anyone that helps me out.
Dont forget
all fluids
serpentine belt
Radiator hoses
heater hoses
I upgraded clutch and resurfaced flywheel
Aeromotive FPR a1000-6
Need to make sure swap comes with
shifter box
shifter cables
ecu
and hope no broken sensors
and Labor for install
I had to use thin fan for radiator
throttle cable bracket
exhaust needs to be done
aftermarket intake if you choose
Thats all I can think of immed
Feel free to call me if any ?'s Richard 540 287 3813
supafly said:
Dont forget
all fluids
serpentine belt
Radiator hoses
heater hoses
shifter box
shifter cables
ecu
Always, have to leave room for stupid little things, you wouldnt expect too. So plan on spending close to 9k for everything
1 - 4 of 4 Posts
