K20a2V8KO said:I know your working on the info...can you also put out specs on the k24 motor as well?
all that displacement!!!!! GOD makes my LS setup look like minse meat. i wish i had the cash man....all motor with k24 bottem with itr top.....hondata and id be set. some mild engine work and you'll be in the high 12'snikos said:K20a2V8KO said:I know your working on the info...can you also put out specs on the k24 motor as well?
Bore: 86mm
Stroke: 86mm
Deck height: 212mm
Rod length: 139mm
Intake Valve: 35.15mm
Exhaust Valve: 30.15mm
Compression Ratio: 11:1
Displacement: 1998cc
Power ([email protected]): [email protected]
Torque (ft/[email protected]): [email protected]
K24
Bore: 87mm
Stroke: 99mm
Compression Ratio: 9.6:1
Displacement: 2354cc
The JDM k24 5-10 TQ difference and no special emission system.vtecboy55 said:are those numbers us or jdm spec? im kinda new 2 the k scence but i think its faboloso!
It's lighter than the H22 definitly, from what I remember the k20a is 22lbs lighter than the b18. B16's are heavier and I think thats where the k24 ends up.AutoWhiz said:I've read it's lighter than a H22, is it lighter than a B18?
Also, weight with tranny?
Thanks,
AutoWhiz
apparently exh mani is diff and something to do with p/s. so itll be fine for the swap. yes they are dated. gotta look where I think it is on the end where tranny is on the head. cant recall with out looking. Ill make sure.bkitr said:I've got a k20a from a CTR for my eg swap. All of the internal engine specs from the CTR vs. the ITR JDM k20a's look the same. Does anyone know why the CTR motor is rated at 215PS vs. the ITR 220PS? Is the loss all in the exhaust?
Also, does anyone know if the K motors are dated in some way like the B-series engines are? I'm just curious to find out what year my motor was made in.
Thanks
i've read on h-t atleast two or three times that it's the same motor and honda did that so the ITR didn't look stupid/satisfy people who bought the itr.bkitr said:I've got a k20a from a CTR for my eg swap. All of the internal engine specs from the CTR vs. the ITR JDM k20a's look the same. Does anyone know why the CTR motor is rated at 215PS vs. the ITR 220PS? Is the loss all in the exhaust?
Thanks
YOu might be referring to the EURO CTR... THE JDM ctr has the same compression as the DC5acchybrid said:CTR compression is 11-1 ITR is 11.5-1 thats were the power differance is at.
