Can enyone tell me if the sump form the B16_b engine will fit the K20a engine do they have the same bolt pattern? Reason for the question is that i need to fit a dry sump pan to our engine and can only find one for the B16 engine the Formula 3 sump pan so will it fit?
Second question we have a K20 engine curretly it is the UK spec engine same as the US spec unit it has K20a2 on the block does anyone know what the more powerful japanese spec engine would say some on said it was called the K20c correct? Whats the differance in part no's and internaly?
Thanks
Henry
Thanks
Henry
