1 - 3 of 3 Posts
What I need to know is the TPS on the K series ajusted to the same ranges as a OB1 car. And is the MAP sensor range the same. Reason I ask is because I will be making a intake manifold for my k20a2 and since I dont have the K series TB I want to use a Prelude TB I have from a 94 and I dont want the ECU to throw codes because the ranges are different. Ill be useing a K pro an I dont know if I can adjust the ranges with a Hondata unit. Any info on this would be a big help. This info may be in a service manual but since I dont have one yet ill ask the K series community.Thanks.
This is what Matt at Hondata had to say. What do you think about what he said regarding the differences in the Idle air control valve?
More than likely this will not work because of the differences in the Idle air control valve. TPS and MAP should be the same, and the K-Pro does not allow the adjustment of readings.
1 - 3 of 3 Posts
