1 - 4 of 4 Posts
I have no idea why my compression is so low. My motor is completely stock. When the motor was out, i used a remote start to do the compression, the first time it went up to like 185 psi, i tried it again and this time, there wasn't any compression at all, like around 35psi. The weird thing is that its now at 30-35 psi all the way across from #1 to #4. i've done a wet test on #1 cylinder and it jumped up to 100. I cannot figure it out, why would it be that low, especially all the way across from #1 to #4. i put my hands infront of the throttle when doin the compression test just to check and it was actually pushing air out then sucking it in......need help
1 - 4 of 4 Posts
