ironBolivianFuego said:What are k20 stock sleeves made from?
yes no problemsBolivianFuego said:But to my next point, has anyone tried using forged pistons on the stock sleeved?
err - no...import_trung said:ironBolivianFuego said:What are k20 stock sleeves made from?
the f series are mmc. (s2000) and so are the h series. the k are iron.Scuffers said:err - no...import_trung said:ironBolivianFuego said:What are k20 stock sleeves made from?
the 'stock' liners are NOT iron, they are MMC
http://www.saffil.com/pdfs/automotive/data/mmcprop.pdf
and good luck if you can find somebody that can machine them, they are hard as nails, hence why people pull them out and replace them with iron (read much cheaper/easier)
Simon,Scuffers said:OK, I am 99% sure they are MMC, but looks like I will have to pull one appart and check....
Actually i believe the S2k and Accord F20 motor(destroked h22) Share the same Sleeves. But here in the USA And in every h22 they have FRM sleeves.import_trung said:the f series are mmc. (s2000) and so are the h series. the k are iron.Scuffers said:err - no...import_trung said:ironBolivianFuego said:What are k20 stock sleeves made from?
ive pulled apart a h22 and a k20, they dont look the same, (that plasticy looking liner in the mmc engines)
90mm, anymore the pistons will hit each other.Kedimoto said:whats the max bore on the stock sleeves?
any companies like darton, etc.. making sleeve kits for the k24 and k20?
