1 - 5 of 5 Posts
TYPE R
Engine specs : DOHC i-VTEC
Bore 86.0mm x Stroke 86.0mm
Displacement 1998cc
Compression ratio 11.5:1
Horsepower : 162kW/8000rpm 220PS/8000rpm
Torque : 206Nm/7000rpm
6 Speed Manual Transmission with LSD
Final Drive 4.764
K24
Engine Type In-Line 4-Cylinder
Engine Block/Cylinder Head Aluminum-Alloy
Displacement (cc) 2354
Horsepower @ rpm (SAE net) 160 @ 6000
Torque (lb.-ft. @ rpm) 162 @ 3600
Bore and Stroke (mm) 87x99
Compression Ratio 9.6: 1
Valve Train 16-Valve DOHC i-VTEC®
TeamPacman said:
TYPE R
Displacement 1998cc
Final Drive 4.764
K24
Yea.. this I know.. but what about the combo k20 head with k24 block, that's what I was getting at.. sorry if I wasn't clear.
TeamPacman said:
Compression Ratio 9.9: 1
Why would the compression ratio change? shouldnt it be the same or do the k24 and k20a have different combustion chambers inorder to increase the compression .3 and would this compression be the same for the tsx and a k20a2 head?
1 - 5 of 5 Posts
