1 - 7 of 7 Posts
So... im getting ready to drop in my motor.
needing a few more things. i know im forgetting something tho....
any ideas?
heres what i have:
k24 block wiseco 12.5-1 pistons h beam rods (from nikos group build)
k20z1 head. complete with everything.
k20a2 engine in my rsx-s now.
new stg cc clutch
act flywheel
header with 3 inch exhaust
k pro. pnf ecu
ep3 trans (til i can can afford to rebuild the type s with lsd...)
ep3 idler pulley.
crower stg. 2 cams.
which valve springs?? which head gasket?? what belt size to keep ac but no ps??
what bolts to bolt up idler pulley??
i know to use the type s oil pump and pan.
anything im forgetting?
this is going in a rsx type s. so keep in mind what i already have stock.
all help is greatly appreciated.
engine/charge harness, crv bracket for the passenger side, axles, clutch line, fuel lines, throttle body, you have all the sensors right?
its going in an rsx-s. so i already have all that. i assume you made that list for a ek/dc/eg swap???
so do i need the crv bracket for an rsx??
IMAKEBOOSTATIDLE
i suggest better cams if u want over 250whp
1 - 7 of 7 Posts
