ok so ive started my build in the last week and i got my the old b18c1 out and ive been prepping the bay for the K.....so as i was doing this i ended up with some questions
1) did you have to remove your ABS system(not hardlines just the box thing by the passenger fender) in order to install your passenger side mount and then reinstall it? ( i have the gen 2 hybrid racing mounts )
2) what did yall do to loop your power steering, i removed the hardline and was just wondering, did yall just leave the hardline and cut about an inch or two before the fitting and strap a hose around it, or did you get a fitting to replace it similar to the one above the hardline that the hose connects to that runs to the power steering pump?
3) i cant find my install guide i got with my mounts, anyone know where i can get one? i couldnt find it on hybrid racings page
4) the harness plugs that are at the shock towers where the engine harness is unplugged for removal of the b series......do these connect to anything on the k series, or am i supposed to remove more of the harness? (please answer with detail)
ummm i think thats it for now, just reply with the # of the question and an answer to keep it simple, thanks ahead of time for all the help:up:
