1 - 10 of 10 Posts
Discussion Starter · #2 ·
Sorry, I just did a search and saw that it is the same swap as a eg. But if you do have any more info or know of somebody that has the k20 in a delsol, let me know.
Thanx
I have a question about the k20 swap into a VTEC model del sol. I was wondering if the engine or exhaust will hit the abs unit? I have a gsr engine with a jackson racing supercharger and I have to run the stock air box b/c the throttle body sits about 2 inches from the abs unit. The rubber pipe will flex to allow it to work but no hard pipe intake will work. I am really considering doing the k series swap but have not been able to find a forum that addressed this issue.
ditch the abs anyhow.......replace it completely with goodridge lines and you'll say abs is for sissy's :p
use your left over abs wheel sensors for traction/launch control instead :up:
1 - 10 of 10 Posts
