I personally have been fighting an oversteering k20eg on the autox tracks. No front bar and too big of a rear one seems to be my problem. I obviously have tons of off power steering, but even on power, I have yet to plow through a corner.
It's 3 wat adjustable. It has 3 holes in the arms that attachs the bar and the endlinks...K2e2vin said:You can search around on H-T(Honda-Tech.com), or go to their webpage for more info(i dont think the site really gets updated though): http://www.a-spec-racing.com
That's almost the same setup I'm running (GSR/ITR front bar / ITR rear bar)...you might run into the same understeering/plowing issues. JDM ITR fr sway bar is 24mm btw.litterbox said:For my track setup I'll be running a jdm itr (23mm I think) front bar and m00gen 26mm rear sway bar with that asr brace to keep the subframe intact. This is on an eh2. Any forseeable problems?
I'm runnin TEIN RS w/12kg front springs /10kg rearslitterbox said:Katman, what coilovers do you use? koni/gc. I'm looking into a setup. Any suggestions?
Why do you guys all run front sways? i never had one on my car and I was really happy with the rotaion that i get with my big rear bar. i felt like I would have changed the handling to much if I added the front bar. Now after getting on the track a few times and doing some other spirited driving I am happy I didn't put my front SI bar that i had on.katman said:That's almost the same setup I'm running (GSR/ITR front bar / ITR rear bar)...you might run into the same understeering/plowing issues. JDM ITR fr sway bar is 24mm btw.
It all depends on what sway bars you are using...that setup would be better for a stock setup, with smaller sway bars or maybe none at all on the rear. I have an EK with 800 lbs front and 400 lbs rear with a stock front sway and a big comptech rear sway, and it is very well balanced.ok thead jacking here, but why do all you guys seem to be running harder on the front than the rear,
correct me if im worng, but i was under the impression you want a harder spring on the back for the eg to induce that rotational moment at lift off and eliminate understeer.
im currently polybushing all my suspension, and have leda dampers with cucso 400lb rear 350lb fronts, or thats how i was gonna set them up, but am i right to set it up like this??
any help appreciated for the unenlightened![]()
