1 - 13 of 13 Posts
What times could i expect when and if i get my k20 type r in my hatch?? It is a dx with full interior. Also it wil have I/H/E with type r ECU!! I know there are lost of variables but i just need an estimate.
I beleive Z10 ran his with a full interior on his mugen comp to a 13.1 with I/H/E and comp.... I beleive he ran a 12.9 with his K-Pro and more seat time practise..
I've run 11.8 @ 112mph in my Hatch but its stripped on slicks and will hopefully soon run a 10 with a Stock K20A-R with adjustable cam gears, DTR header, NO exhaust, TWM ITB's and Standalone comp...
I think i seen that guy on Honda-tech, hes from australia or something. Either way those are good times for street tires, do you know what kind of suspension he is running or what suspension are you running?
He is running some heavy shocks and spring but his is more circuit racing set-up..
Me I'm running a solid rear with custom shocks and springs in the back... We started with 600lbs in the back and have been running high 1.6 60fts so they have been binned and I have installed some 1000lbs in the back to try and get it to hook up better...
In the front I run a pair of Koni's they are height adjustables, with individual bound and rebound adjustment... I also run some home build traction bars..
www.jdmyard.com
hi,
we have cusco zero 2 coilover with 12k front springs and 18k rear springs
we managed to clock a 12.9 (1.9 60ft) pass with mugen n1 ecu /custom CAI/dtr header and a 2.5" catback system (cat included)
car weight 2200lbs with driver
205/50/15 BFG D/R
thanks heaps to non-vtec and nikos for their advices! :D
getzy said:
Thanks fellas, I was hoping i could get into the 12's but i guess i'll have to wait and get pro after i finish the swap!!
i have a friend with a k20 eg......he ran 13.4's with street tires.....
if you wanna hit 12's spray.....but if you wanna hit 11 go turbo :mrgreen:
www.jdmyard.com
what setup doesn your fried has?
1 - 13 of 13 Posts
