1 - 2 of 2 Posts
Hi all,
I know that this is an often discussed subject however I would like someone to confirm if this setup works or not. A K20A2 will be dropped in my eg soon and would like to swap to a full disc 5 lug / stud setup.
For the front:
(whole set including rotor, calipers, hubs etc), I will be using a 2001 CR-V that had a b20z1 engine (auto gearbox)
Shafts kswap 36mm ones or will the CRV ones still work (maybe keep them as spares?)
Not sure for the rear but if I get a civic 4 lug set up and use Type S 5 lug Hub, wheel bearing, Brake Calipers & Brackets + Rotor, will it work straight away without any modifications?
Thanks!
Discussion Starter #2
I was also readying about some alignment issues once the CRV parts are installed..maybe someone can elaborate a bit more.
1 - 2 of 2 Posts
