1 - 1 of 1 Posts
Engine:
k20a2 la sleeved 87mm
Arias custom 10:1 pistons
Bme rods
All Coated bearing
Modded s2000 pump
L19 headstuds
Hybrid racing tensioner
Skunk 2 Billet side cover
Aluminum Chain guide
Oem steel pan
Prb cylinder Head
Ferrea Valves
Ferrea guides
Ferrea springs and retainers
Bc stage 2 cams with vtc
Ktuned water neck
K tuned Electric water pump kit
KLM radiator with 16 an braided
Lines
Transmission: Factory k24 AWD tranny will add wave trac AWD led not installed.
For extra $7500 can add ppg i have new in box.
Clutch: comp twin disk
Fuel system: 8 gallon tank in trunk
10 an feed
8 an return
Areomotive brushless 5.0 pump
8x2200cc bosch injectors
Weldon regulator
AEM psi sensor
AEM oil psi sense
Gato 8 injector aluminum intake manifold
tuned 90mm tb
7 bar hondata map sensor
accuritytps
las alpha clamp
Turbo Kit:
elm turbo manifold
60mm tail gate
dump tube 3.5 inch up pipe.
Borg Warner 72mm see rated 1100hp
1400 hp elm 6 inch back door intercooler
50mm tail blow off valve
Wiring:
brand new poem engine harness.
new boss man relay box
wire works switch panel
AEM v2
red top 12v car
Interior:
10 pt chromoly cage with shout
kirkey seat
personal steering wheel
ktuned race spec shift box
ktuned oem cables with race bushing
jeg rear break blue knob
complete ex interiors gem original
power windows
Suspension:
front box drag coilovers
skunk 2 camber kit
elm bushing kit
stock axel
front traction bar
Rear:
oem modded arms
stocks wagon left axles
oem wagovan diff
Modded wagon driveshaft new front knuckle.
Wagon viscous coupler
elm rear control arms
elm rear camber kit
Complete finishing brake line
wildwood brake delete
Black works clutch kit and line.
$29,000 OBO
contact me (786)600-8022
SERIOUS BUYERS ONLY
1 - 1 of 1 Posts
